Shatterin W108 250S -67
Petteri Kivimäki
Re: Shatterin W108 250S -67
Minulla on sellainen joka pitää jotenkin painetta. :wtf:
Taidan vaan maalata ja laittaa uuden palkeen, kun just nyt ei ole tonnia-kahta laittaa huoltoon. Paljonkos se huolto muuten Saksanmaalla lopulta olikaan?
Kuten viime kesänä tuolla omassa langassani kirjoitin, se korvaava jousi oli omassani kamalan huono ratkaisu; jousi nosti perän ihan hervottoman korkealle ja takarenkaat negatiiviseen camberiin. Olisi sianraadon tarvinnut takakonttiin..
W246 "Kaasukoppi" B200 2015
Shatter
Viesti Kirjoittaja Shatter »
Saksan foorumilta löytyi Boge aarteita, täyttöpaine mallista riippuen 60/75bar ja ilmeisesti ZF käyttää nykyään korjatuissa vain 75bar painetta.
Koodi: Valitse kaikki
There were four types. Two with 50 bar, two with 75 bar, each 368 and 374 mm long, respectively.
The strongest had a green stripe on the pressure hull, was around 75 bar, 374 mm long, and was for station wagons, police cars, and ambulances (111 320 04 99).
The next one of the same length (111 320 02 99) was for rough roads and had a pressure of 50 bar.
The 01 99 and 03 99 are 6 mm shorter.
The 01 99 went into the 220SE Cp / Ca, the 04/99 into the 250 Ca / Cp.
In other words, the short axles (4.08, 4.1) had the short leg.
Hello,
So I've contacted ZF.
As mentioned in the linked topic above, all ZF overhauled bow struts have the same pressure (phone call with Mr. Münchrath - 75 bar).
Ms. Jung sent me a blank order for the Hydromat.
It lists the costs for the repair in detail.
If the Hydromat requires the full program, the repair (if I understood correctly) will cost €966.99 (including 16% VAT).
Depending on how much you can get a used bow strut for, it might be worth buying a reconditioned one directly from ZF.
Mr. Münchrath mentioned €1,200 including shipping.
Maybe I'll actually do that.
That way I'll save myself the hassle of looking for a used one and the time of sending the Hydromat in for overhaul.
Attached are the contact details of Ms. Jung and Mr. Münchrath:
Stefanie Jung
Core Engineering
Forschung & Entwicklung Pkw-Fahrwerktechnik/
Research & Development Car Chassis Technology
ZF Friedrichshafen AG
Pkw-Fahrwerktechnik/Car Chassis Technology
Dämpfungsmodule/Suspension Technology
Bogestr. 50, 53783 Eitorf, Deutschland/Germany
Telefon/Phone +49 2243 12-423, Telefax/Fax +49 2243 12 95423
stefanie.jung@zf.com
Peter Münchrath
Application Engineering
TechCenter Europe
Bogestrasse 50, 53783 Eitorf, Deutschland/Germany
Telefon / Phone +49 2243 12-489, Telefax / Fax +49 2243 1295 489
peter.muenchrath@zf.com
MB W108 250S '67
BMW E91 330d xDrive '09
Skoda Superb mk2 2.0tdi DSG '13
MZ RT 125/3 '62
Petteri Kivimäki
Lerssinen kirjoitti: Ti 29.04.2025 18:53 Tohtii, just tuollaisen vaihdoin omaan 108:iin ja napsahti paikoilleen ihan komeasti :thumbup:
No tuli säästettyä väärässä paikassa? Halvemmassa tanskalaisessa yhdystangossa on joko ohjausiskarin pultin kierre eri kuin alkuperäisen tiheä ja tai sitten tekemisen laatu on sinnepäin ja pulttia ei saa suoraan mutteriin että lähtis kierteelle.
Voi Kyrv4nsyyl4 näitten kanssa. Ei kun irti ja IKH:lle etsimään sopivaa pulttia.
Älkää ostako tätä..
Petteri Kivimäki
Vääntö&paukutus&twist&shout. Kierteet on maalattu, mutta eihän mulla tuollaista tiheäkierretappia. Suunnilleen hollilleen että ehkä vois kierteillä olla ja pulttipyssyllä kiinni. Eipä tuota minun elinaikana uusita, sniif.
Shatter
Tässähän on taas perinteiseen tyyliin työt haitannu harrastuksia. Lomarahat ja vähän päälle tuli tänä vuonna sijoitettua kirjaimellisesti tähdelliseen kun tilasin akselistojen kasaukseen kaikki tarvittavat sekä 5L epoksia niin saa läträtä korin pohjaväriin. Kesälomalle tavoitetta, sään salliessa. :angel:
Hieman jo jänskättää perän laakerointi/säätö. :mrgreen:
MB W108 250S '67
MZ RT 125/3 '62
Shatter
Perään liittyen dokkareita, iso kiitos Multivirille :thumbup:
Pinionin mittaukseen sekä muuta teknistä tietoa.
Backlash arvoksi annettu 0.15mm +-0.02mm, joku toinen manuaali kertoo 0.08mm - 0.14mm
Jos nyt oikein konvertoin tuon manuaalin antaman cmkp ja mkp arvot nyyttoneiksi niin
1mkp = ~10Nm
10cmkp = ~1Nm
Aika hiuksen hienoa on kun pelkälle pinionille annetaan pyörintävastukseksi uusilla laakereilla 16-18cmkp eli 1.5Nm, sen jälkeen poskilaakereiden esijännitys siten että kokonaisvastus nousee 7-8cmkp eli about 0.5Nm? Perä nipussa pyörintävastus siis 2Nm luokkaa.
Torque when turning complete differential on jo sitten 15-20nm eli käsittääkseni vetoakselit paikallaan, akseliputket suorassa mutta jarrupalat irti.
Tästähän voi tehdä kovinkin vaikeaa numeroita tuijottamalla, siitä lähdetään että uusitaan laakerit, kasataan vanhoilla shimmeillä ja tarkistetaan.
Edit: niin joo hoksasin tuosta linkun puolelle tulevasta nivelestäkin että pitäisi olla shimmattuna sopivaksi että hitaasti valuu alas omasta painosta. Ainakin tässä on nivel ihan löysä, en ole sen enempää tutkinut onko siinä välystä kun en purkaessa ajatellut että siinäkin olisi jotain säätöjä.
MB W108 250S '67
MZ RT 125/3 '62
Petteri Kivimäki
Shatter kirjoitti: Su 29.06.2025 10:38 Perään liittyen dokkareita, iso kiitos Multivirille :thumbup:
1mkp = ~10Nm
10cmkp = ~1Nm
Matkustan Ouluun, Hazetin heittokello ja perä repussani.
Shatter
Akselistojen kasausta koitettu laittaa alulle.
Uudet laakerit asennettu perään ja pinioni säädetty, pyörintävastus nyt 1.5Nm
Aika nahkea pyöritettävä tuli, laakereihin laitoin öljyä kasatessa ja stefalle ohuesti laakerirasvaa ettei vääristä tuloksia, jos edes on vaikutusta.
Poskilaakereissa oli pöydällä mitattuna ~0.10mm paksuus ero vanhaan joten epäilen että niiden kanssa joutuu painimaan.
Seuraavaksi olisi sitten tarkistus hammaskosketukselle värin kanssa sekä backlash ja pyörintävastus nipussa.
Pinionin ulkokoolit on törkeän tiukalla sovitteella, lämmitin kuoren kosanilla reiluun 100 asteeseen niin ei puhettakaan että olisi kooli tipahtanut paikalleen, kevyellä koputtelulla meni 2/3 asennusmitasta ja loput joutui painamaan kierretangolla vanhaa ulkokoolia hyödyntäen.
Pyöritykseen tilasin ihan analogisen momenttiavaimen 0-14nm alueella, Park Tool TW1.2 ~40e.
MB W108 250S '67
MZ RT 125/3 '62
Shatter
Tankki valmis, vaihdoin vielä uuden korkkitiivisteen korkille ja suodattimen pohjaan.
Yritin alkuperäisiä vaimennuspaloja matkia käyttäen 13mm armaflexiä.
Korin kanssa pidin pari jäykkää päivää sulkeisia niin sai reseptin valmiiksi: kevyt puhallus, hionta/mattaus, rasvanpoisto ja epocoat 21.
Epoksia meni tasan 5L kun kiersi koko kopan kerran läpi. Olipas muuten mahdoton ero kun aiemmin maalasin tankin ja pikku hilpettä 1.4mm HVLP ruiskulla, koria varten hommasin LVLP 1.8mm suuttimella niin tavara tuli läpi ihan itsestään :)
Pitkälti nyt paljaat peltipinnat suojattuna joten saa kuivua rauhassa ennen saumauksia ja pintamaalia. pyöränkaaren taitokset takana ja ilmanottokotelo vaatii pientä touch-up pensselöintiä kun ei ihan joka paikkaan ruiskulla mahtunut.
MB W108 250S '67
MZ RT 125/3 '62
Petteri Kivimäki
Komealta näyttää!
En saa mielestäni sellaista mustaa Mersua pornonpunaisella sisustalla.. :wtf:
Orlov
Viesti Kirjoittaja Orlov »
Minä näen hiiren harmaan punaisella sisustalla :) (tai siis hopeanuolen)
Mutta nyt on kyllä pinkka ja asenne kohillaan rakentelun suhteen!
