Im having this project on a '88 w124. Used to be a petrol 300E, but is now converted to the OM603-engine.
Building a setup based on twostep charging - two turbos with different size to reach low lag and high pressure. We'll see how that will work on a small engine like this.
My engine is the 603.912, nonturbocharged from the beginning. Am I correct to say that the weak point on this engine is the pistons?
What can I expect if I try to reach over 400whp with this stock engine?
I am pretty much ready to send my pump for modification. Planing to send the pump to Mynä - Ive heard they are the best at what they do. I have seen a phonenumber to Mynä, is that the best way to get in contact with them?
