Saisinko W115 kantakortin tulkintaan apuva!
- Petteri Kivimäki
- Viesti:
Löytyi Vesa-Erkin kantakortti.
Ymmärtää 606 70-luvunkeltainen ja 063 sen konjakinväri-sisusta, mutta mitäs muuta ilmenee, osaako ja viitsiikö joku tulkata tai jeesata, mistä löytyy tieto tulkitsemiseen?
EQA 250 2021
Re: Saisinko W115 kantakortin tulkintaan apuva!
Vanhan EPC:n tietokannasta suoraan sql:llä, valitettavasti aika vajavainen n. pre 1985 koodien kanssa. Merkitykset ovat vaihtuneet ajan saatossa ja mallien väleillä mutta kenties jotain osviittaa:
"CLASS","SACODE","TYPE","A_DATE","A_DESC"
"C","247",,"19620701","COLD START BATTERY"
"C","247",,"19640701","REAR WINDOW, ELECTRICALLY HEATED (SAFETY GLASS)"
"C","247",,"19891001","ELECTRIC SEAT ADJUSTMENT (FRONT PASSENGER SEAT) - ADDITIONALLY ADJUSTABLE THE REAR."
"C","401",,"19620101","SINGLE SEATS"
"C","427",,"19641001","MERCEDES-BENZ POWER STEERING AND MANUAL TRANSMISSION WITH FLOOR SHIFT"
"C","483",,"19640101","HARDER SPRINGS AND UNDERSHIELDS"
"C","524",,"19620401","REIMS ADAPTER IV"
"C","524",,"19640101","PAINTCOAT PRESERVATION"
"C","553",,"19650301","TRAILER COUPLING AND ANTI-THEFT WARNING SYSTEM"
"C","553",,"19660201","DUST SEALING FOR BODY"
"C","553",,"19781101","TRAILER COUPLING AND ANTI-THEFT WARNING SYSTEM FOR SWITZERLAND"
"C","618",,"19700401","HALOGEN LAMP UNIT WITH HIGH BEAM/LOW BEAM/FOG LIGHT (R.H. TRAFFIC)"
"C","636",,"19650101","15 TIRES"
"C","636",,"19650801","15 TIRES"
"C","636",,"19730301","ELIMINATION OF WARNING TRIANGLE"
"C","656",,"19630101","VEITH TIRES"
"C","656",,"19650801","MICHELIN TIRES"
"C","656",,"19930601","LIGHT ALLOY WHEELS, 10-HOLE"
"C","667",,"19630101","DISC WHEEL WITH CHROMED KEY"
Myöskin tilausnumeron ensimmäinen numero 5 = tilattu 19X5 ja seuraavat 529 = Suomi, loput järjestysnumero
Viimeksi muokannut ATa, Pe 28.08.2026 18:08. Yhteensä muokattu 2 kertaa.
Eikös 427 ole ohjaustehostin.
Sivullisille tiedoksi, 063 sisustus ei ole konjakinvärinen
- Petteri Kivimäki
- Viesti:
No joku hyvänmakuinen viina kumminkin tuo väri!
Niin aluvanteetko ja 15". Mistäs mää nyt 15" barokit piaraasen!
EQA 250 2021
- Petteri Kivimäki
- Viesti:
Kiito! Takalasinlämmitin osuu, ohjaustehostin ja lattiavaihde osuu ja jäykemmät jouset on samat kuin W114, koskapa koneessa on viis pyttyä neljän sijaan..mutta 15" renkaat kuulostaa kyllä eksoottisilta. Oliko niitä lisävarusteena W115?ATa kirjoitti: ↑Pe 28.08.2026 17:59 Vanhan EPC:n tietokannasta suoraan sql:llä, valitettavasti aika vajavainen n. pre 1985 koodien kanssa. Merkitykset ovat vaihtuneet ajan saatossa ja mallien väleillä mutta kenties jotain osviittaa:
EQA 250 2021
https://oudemercedesbrochures.nl/W114Po ... _0575.html
Esite tietää kertoa sisustan värin nimeksi mahonki.
Semmonen erikoinen havainto, että esitteen taulukon mukaan ulkoväri 606 ja sisustan väri 063 eivät ole sallittu / mahdollinen yhdistelmä, mutta siinä ne molemmat vaan kantakortissa silminnähden seisovat.
- Petteri Kivimäki
- Viesti:
Eikä sunkaan muuten ole ainoa auto, jossa väri 606 Maple Yellow ja sisusta 063 Mahonkiviina.Nozki kirjoitti: ↑Pe 28.08.2026 23:42 https://oudemercedesbrochures.nl/W114Po ... _0575.html
Meneekös näissä vanhoissa kontrasti niin, että maalin väri tumma - sisustan väri vaalea, maalin väri vaalea - sisustan väri tumma?
EQA 250 2021
AI kertoilee, että "For cars built from March 1973 onward: Code 636 meant "Elimination of Warning Triangle" (Wegfall Warndreieck)."
Niin, edellä olevassa taulukon päivämäärä tarkoittaa ko. koodin merkitystä siitä lähiten. Eli auton toimitusajankohta määrää koodien merkityksen.
