The BIG
Linkkejä Mercedes-Benz-aiheisille sivuille.
Jori K
The BIG
Viesti Kirjoittaja Jori K »
Venäläistä tuningia by A:level. The Big:istä löytyy 850 hummaa:
http://www.alevel.ru
- niin ja onhan siellä se American Car Showssakin taannoin näytillä ollut ultrasiisti Volga V12...
mikäs tuon bigin tarina on ?
autohan on aika kopio mersun c124 ....
Jori K
Mercedes Benz W140 Coupe was chosen as the donor, which is pleasant in driving car due to optimum appropriate requirements of comfort level, and, at the same time, "not overloaded by artificial intellect".
It is supposed to make the following operational development:
• Increase the output of original 6L engine up to 850 h.p. by setting two turbo units with intercoolers.
• Setting of the manual transmission to conform to torque.
• Setting anew designed front and a rear struts; racing brakes.
• Elaboration new functional design of a body to provide appropriate aerodynamic quality, high clamping force, and its uniform distribution on axels.
Settlement dynamic characteristics:
– The maximal speed – over 300 km/h;
– Acceleration up to 100 km/h – within the limits of 5 sec.
Primer display is held in autumn of this year, in Moscow, after passage final full test, which take a place on the big ring "Nurburgring" (Germany).
EDIT: a:levelin v.2001 pressitiedotteesta lainattua
EDIT 2: Lisää aiheesta:
http://www.topgear.com/content/features ... russia/04/
