hello,
I am just installing a OM606A into a 350GD.
I will use the OM603 pump... so which injectiontime should I use?
regards
OM603 pump on OM606. which injectiontime?
...and in stock injection pump, the mark does not show the real injection time. Instead the mark should be in place when there is about 13...15 degreas after top dead center in crankshaft (cylinder 1 in work).
