124 CABRIOLET E 320
koiva
124 CABRIOLET E 320
Viesti Kirjoittaja koiva »
olis todennäköisesti kaupan tällänen yksilö
mutta kertokaa mikä ja kuinka tehokas moottori
tässä on?
VIN WDBEA66E0SC277059
Model E 320 / E36 AMG
Chassis 1240661C277059
Engine 104992 12 098267
Transmission 722369 04 174935
Order 0 5 704 38334
Delivery date 17.08.95
Dealer United States (USA) (704)
Interior leather mushroom (265)
Paint
149 polar white (T) (с 01.01.1992)
Options
222 right front seat, electrically adjustable (с 01.11.1978)
241 left front seat electrically adjustable with memory feature. only applicable to w 210 when installed in conjunction with code 275. (с 01.03.1983)
251 radio MB-Exquisit - USA (с 01.07.1992)
283 draft deflector (с 01.07.1989)
291 airbag for front passenger
airbag for front passenger (с 01.10.1993)
airbag for driver and front passenger (if driver airbag standard - then only for passenger)
300 storage box in front tray (с 01.05.1988)
340 additional 3rd stop lamp (с 01.10.1989)
420 automatic transmission, floor shift (с 01.01.1963)
441 steering column, electrically adjustable, W202 manually adjustable (с 01.07.1984)
440 tempomat (cruise control) (с 01.09.1975)
461 instrument with mileage reading and english lettering (с 01.04.1990)
494 California version
California version (с 01.05.1973 по 31.12.1995)
524 paintcoat preservation (с 01.01.1964)
551 anti-theft warning system (с 01.11.1978 по 31.03.1998)
581 automatic climate control (с 01.01.1977)
593 heat-insulating glass, all-around, heated rear window pane (single-sheet safety glass), band filter
green heat-insulating glass all round, heated rear window, single pane safety glass - tinted strip (с 01.01.1972)
600 headlamp wiper/washer (с 01.08.1971)
636 elimination of warning triangle (с 01.03.1973)
634 elimination of first aid box (с 01.08.1977)
652 8-hole light alloy rims (с 01.01.1990)
668
740 folding top fabric9001 black (с 01.08.1972)
805 Change of year of model, last figure shows new model year
814 active bass loudspeaker system (с 01.10.1989)
916 Unknown code
C107 450SLC 5,0 -80, W108 280SE 4,5 -72, W110 200B -66, W114 230.6 -71, W115 22OD nyt 250B -73
W116 280S -72, W116 280SE-73, W123 300D -78, C124 230E -87, W124 200E -87
W124 300DT -87, W124 200E -88, S124 300E -92,S124 300 TDT -88 S124 300 DTD -91, W124 200D-94, W126 280SEL-81
W201 190 -83, W201 190E-87, W201 190E 2,6 -88, W209 200 K -03, S211 E270 Cdi-04
ex,W245 B170 -05, W201 190E -88, S124 300D -85
3,2l suora kutonen 220hv. Älä sitten säikähdä kaikkia vikalistauksia mitä ko. moottori voi tuoda tullessaan kun käytät hakua.
koiva
mitä toi E36 AMG
tarkoittaa
opcaravan
Viesti Kirjoittaja opcaravan »
koiva kirjoitti:mitä toi E36 AMG
tarkoittaa
Tarkoittanee kaiketi sitä, kun tästä mallisarjan 300/320 sarjalaisten pohjalta on tehty myös nämä amg versiot?? Sergey kertoo sit faktaa enempi =D
Mut mulla kans näyttää tollein tuon vin cooderin mukaan.
Mercedes 300CEA 24V -91
Seat Cordoba 1.9Tdi 66kw vario/paku -00
joo noin se jotenki sujuu. AMG:n moottorikoodi on M104.941
siis "Engine: 104941 xx xxxxxx".
esme
Viesti Kirjoittaja esme »
California version (с 01.05.1973 по 31.12.1995) <-- Mitähän tuo tuo tullessaan?
Mr300
Viesti Kirjoittaja Mr300 »
opcaravan kirjoitti:
tarkoittaa
Mullakin sanoo Oma 300ce 24v vin, (Model 300 CE-24,AMG 300 CE 3.4) Eli tästäkin on varmaan veistetty tota AMG:tä
MB 220CDI C -07
MB 300CE-24 -92
MB 300D -79
esme kirjoitti:494 California version
amerikkaan tuo on uutena myyty, elikkäs mitäs siinä nyt mukana tulee, ainakin hiton rumat "polvitörmäyssuojat" mitkälie sisällä, ovissa sivutörmäys putket, mailimittari , mitäs muuta ? koneessa voi jotain ekstra saastejuttuja olla.
Mr300
Sori mä viel varastan tätä topicia niin pisti silmään tuo dealer. Itellä lukee näin (Dealer company employees / MBAG (297)) Elikkäs onko tämä mb työntekijän ostama?
MB 220CDI C -07
MB 300CE-24 -92
MB 300D -79
joo noi pehmusteet ja EGR ainaki o amerikkakamaa ja voi olla että konees o pikkuse pienemmät puristukset, mut en ole varma 3,2l koneen osalta.
PepeKyy
Viesti Kirjoittaja PepeKyy »
Ameriikan mallissa taitaa olla myös keski jarruvalo upotettuna takaluukkuun.
Kalusto:
Mersu(ja)
Timo N
Viesti Kirjoittaja Timo N »
jumalauta koiva, cabriolet, ekkös sää tiä että vanhan miehen niskat voi tulla kipiäks tossa kyytissä
W126 500SEL -86
C124 320CE -92
R129 320SL -95
jokatapauksessa jos se on siisti ja pelaa hyvin eikä hinta hirvitä, niin miksi ei. Kyl minäki viel joskus...
esme
Juu, kyllähän tuommonen kelpais : http://www.autotrader.com/fyc/vdp.jsp?c ... l=E320&num
no oho ompa ne kalliita rapakon takana.
esme
Taitaapi olla amg..tosin VIN koodi taitaa olla väärä
PepeKyy
Ei toi nyt kalliimmasta päästä ole jos toi on kunnossa. Hyvät ja vähän ajetut on saksassa 15-20ke paikkeilla. Linkissä oleva vaikuttaapi hiukan räpelletyltä :roll: Aitoon AMG cabrion hintaan saa laitta hiukkasen kertoimia lisää.
Kalusto:
Mersu(ja)
esme
Noin surkeista kuvista ei räpellystä erota, mitä nyt tuo maski hyppää silmille. Harvoinpa niitä myynissä on, että sais referenssiä.
Arto N
Viesti Kirjoittaja Arto N »
Timo N kirjoitti:jumalauta koiva, cabriolet, ekkös sää tiä että vanhan miehen niskat voi tulla kipiäks tossa kyytissä
Voihan se olla mutta yhtään en pahana pitäisi että saataisiin tuollainen auto tuohon Sahramin nurkille pyörimään. Olis siinä perus Sahalahtelaiset ihmeissään :lol:
<-- Tämä projekti ensin
W124 250 TD -92
Ex w123 240 D -80
Timo N
kunhan löpisin, eihän toi oo ees vanha vielä, ei muuta kun koiva rupee vähän pöyhiin alimmaisia, oishan se komee
W126 500SEL -86
C124 320CE -92
R129 320SL -95
Efraim
Viesti Kirjoittaja Efraim »
Morjens,
Tuon jenkkipelin keula on outo. Lieneekö se tuunattu SL:ksi, sillä maski ja vilkut eivät ole W124:stä.
Muuten varsin vaikuttavan näköinen peli. Tuon penkillä ei parane istua remppahaalareissa eikä tummissa farkuissa. Herrasmiehen vehje ja liian hieno näille leveyspiireille. :(
