Hi, I have a OM606 912 from a `95 E300D, I thinking about turbocharging this engine, I want to do it properly, so I want to change the pistons and con-rods for Turbo, The con-rods can be used from 603A, but the pistons are not the same obviously.
I`m thinking about 6,5 mm pump elements, proper exhaustmanifold(skyline?), bigger turbo...
I want to get approxematly 250+ hp with good MPG and a safe engine to drive with.
What do you think, does anyone of you know of pistons cheap, thinking about bigger bore.
Is it smart to use the 606N/A block or a 603A block?
606-turbo
- Forced_Induction
- Viesti:
Re: 606-turbo
You will need to machine the block and fit oil jets for the pistons.
I would be much cheaper to swap a good used 606a into your car.
1982 300D
Maxed MW-Pump, Holset HE221W, straight pipe exhaust, A/W intercooler, W/M injection
W115 300D intake manifold, 2-Micron Baldwin BF7591-D fuel filter, W126 Gen-II front brakes
Webasto TSL-17 auxiliary hear, Battery relocated to the trunk, Factory skidplate, 15mm rear sway-bar
147HP, 220lb-ft at the rear wheels
2006 Honda Rebel Turbo Diesel
Kubota OC95, VZ21 turbocharger, Intercooler, Comet 40C/44D CVT
Re: 606-turbo
They have oil jets original all 605 and 606, even W/O turbo.
Mercedes Benz 300 TD Turbodiesel
123.193 OM617.952
1,2 bar turbopressure
Ford Granada 2.8 Ghia, 180 hp, 5-speed, 3.45:1
Ford Granada 2.0
123.193 OM617.952
Ford Granada 2.0
- Forced_Induction
- Viesti:
Re: 606-turbo
The pistons rods and crank are not the same.
1982 300D
