törmäsin tälläiseen aiheeseen valmistajan sivulla.
http://support.dension.com/support-cent ... =12&id=110
Onko forumilaiset päivitellyt omaa gatewaytä ja onko mitään hyötyä?
Dension Gateway 500 Päivitys?
Kryptonite
220.128 Black Mirror
Aikas paljon olisi tullut uudistuksia tietty riippuu mikä version on nyt, kopion sen zip in liitteestä, jahka Rouva palaa ostoksilta katsotaan mitä tapahtuu.
Toivottavasti ei mykisty se meinaan oli "rikki" pari kuukautta kun en tajunnut että sen saa resetoitua kun se meni mykäksi ja kehuja tuli " ei täällä stana mikään toimi"
GATEWAY 500 D2B MERCEDES FIRMWARE HISTORY:
v. 2.10
New feature:
- When iPod is in STOP state, a second track is added, enabling quick access of the Play All function
Modifications:
- Default iPod GW Interface mode changed to iPod User Interface mode
- When you quit from the Menu with SeekBW (seek backwards), it always returns to the default disc (Disc 5)
instead of the previously selected disc
Bug fix:
- BTA: Improved operation with Symbian 9.1 phones
v. 2.08
Modifications:
- iPod display: modified due to the limitations of new iPod Nano3 and Classic v1.0.3 firmwares. While
iPod is playing Dension logo is displayed on the iPod screen.
- iPod welcome screen changed to a single page, containing "DENSION", "www.dension.com", version
number and service tag.
Bug fix:
- During the shutdown process, when an iPod is connected, in very rare cases the GW500 froze, only
removing the iPod helped. Fixed.
v. 2.05
Modifications:
- BTA driver: BTA1000 displays call time when call is in progress.
- Seek forward / backward changes to higher speed after some seconds of seeking in a song.
Bug fixes:
- USB: An incomplete song database was not saved to the drive. Fixed.
- When a device was connected and disconnected while device change was in progress Gateway 500 stucked in NO magazine state. Fixed.
Known limitations:
- NONE
Known Bugs:
- NONE
Tech. Info:
v. 2.03
Modifications:
Bug fixes:
- Gateway 500 is not changing the repeat and random settings of the HU after ignition
is turned on, or CDC source is switched back from FM.
- USB related: Gateway 500 sorts out empty or corrupt playlists from browser database.
- BTA driver: GW software crashed when SEEKBW was pressed on the setup disk. Fixed.
Known limitations:
- NONE
Known Bugs:
- NONE
Tech. Info:
v. 2.00
Modifications:
- Major change in HMI. Read carefully the new User Guide! Download it from:
http://www.dension.com/download_icelink.htm
- New User Interface, including:
Source Selection in Menu
Bluetooth support with BTA 1000 accessory.
Advanced USB handling, ID3 browser
- This and upper firmwares give you the possibility to connect Dension accessories to your
Gateway 500.
Bug fixes:
- “No sound after ignition turned on” problem with Audio 10 Becker 6210 HU is fixed.
Known limitations:
- NONE
Known Bugs:
- NONE
Tech. Info:
- The power harness was modified. See details in the installation manual.
Download the new Installation Guide and User Manual from:
v. 1.05
- This firmware version has been released mainly to support changes in factory testing
of the GW500 hardware.
iPod_ext
- In Pause state after changing track and sending Play command, the iPod stuck into Pause.
Fixed.
v. 1.04
CDC
- Selecting a disk and immediately selecting the previous
disk caused some head units stuck in “loading disc” state. Fixed.
USB
- Increased speed of SeekFW and SeekBW.
- Fixed buffer handling bug, which caused very end of audio files was not played.
- When changing USB stick (same or different one), random and repeat
mode sometimes was not set or displayed properly. Fixed.
- Left and right audio channels were swapped when playing WAV files. Fixed
Known Bugs:
- None
v. 1.02
- Compatiblity with latest iPod firmware (September 2006)
Known Bugs:
- None
v. 1.01
Known Bugs:
- None
v. 2.10
New feature:
Modifications:
Bug fix:
v. 2.08
Modifications:
Bug fix:
v. 2.05
Modifications:
Bug fixes:
Known limitations:
- NONE
Known Bugs:
- NONE
Tech. Info:
v. 2.03
Modifications:
Bug fixes:
Known limitations:
- NONE
Known Bugs:
- NONE
Tech. Info:
v. 2.00
Modifications:
Gateway 500.
Bug fixes:
Known limitations:
- NONE
Known Bugs:
- NONE
Tech. Info:
v. 1.05
iPod_ext
Fixed.
v. 1.04
CDC
USB
Known Bugs:
- None
v. 1.02
Known Bugs:
- None
v. 1.01
Known Bugs:
- None
Hummer H2
W203-C32AMG
ex VMax
ex 190E 2.3-16
ex W220 S500 full loadet
-loesje-
W203-C32AMG
ex VMax
ex 190E 2.3-16
-loesje-
No niin ilmeisesti päivitys onnistui koska toimii edelleen, ns. versiosivu vilahtaa ipodin näytössä niin nopeasti etten ehtinyt nähdä mikä versio on pelissä.
Eli ei ainakaan jysähtänyt hyödyistä ei havaintoa
tosin en kyllä osaa käyttääkään sitä, että näin, ei ihan yhtä kattava raportti kuin yleensä esim jäsen eerolalla
mutta edes jotain sain sanottua.
Hummer H2
W203-C32AMG
ex VMax
ex 190E 2.3-16
-loesje-
W203-C32AMG
ex VMax
ex 190E 2.3-16
-loesje-
