Nice forum.
Mercedes-Benz conversations only
janli
Nice forum.
Viesti Kirjoittaja janli »
You have a truly nice forum. :wink:
You is welcome that visit http://www.mb-forum.se
Swedens greatest mercedes forum.
If you registers yours forget don´t that fill in place (ort).
Site-admin/mb-forum.se
Kipsu
Viesti Kirjoittaja Kipsu »
Thank you and welcome to chat with finnish Mercedes euthuasists.
I have allready registred in your swedish forum as you might have seen. :wink:
SLK_55_Kleemann
Viesti Kirjoittaja SLK_55_Kleemann »
Yes, this is a nice forum, i also found it with som help from Kipsu - thanks mate! 8)
[img]http://img204.imageshack.us/img204/5232/dsc01543ji5.jpg[/img]
SLK 55 Kleemann -06, Lotus Esprit V8 Biturbo -96, Harley Lowrider -06
janli
It is thank's to you Kipsu that we have launched up an International section.
I hope that we in the future can do something together. (perhaps
a mercedes meeting in Sweden). :wink:
Kipsu
Re: Nice forum.
janli kirjoitti:You is welcome that visit http://www.mb-forum.se
URGENT:
Dear collegues
All whom are going to register MB-Forum.se, please read this carefully:
When you fill in the registration form please fill section "ORT" with the place you are living in. Example: "Finland / Espoo." It is recommanted to fill it because it is also preventation against spammers whom try attempt to register. Same in finnish:
TÄRKEÄÄ:
Hyvät toverit
Kaikki jotka aikovat rekisteröityä MB-Forum.se -sivuille, lukekaa tämä tarkasti:
Kun täytätte rekisteröintikaavaketta täyttäkää kentän "ORT" paikkakunnan nimellä jossa asutte. Esimerkiksi "Finland / Espoo." Sen täyttäminen on vaatimuksena koska ko. kentän tarkoituksena on myös ehkäistä roskapostittajien rekisteröitymistä.
Kiitos | Thank You | Tack
Terveiset | Greetings | Hälsningar
MB-Forum.se site admin / Jan
janli kirjoitti:It is thank's to you Kipsu that we have launched up an International section.
It would be nice! 2-300km from sthlm... And if someone dosn't talk swedish or english, couple Kosken drinks will open the language barrier ;)
Oloffi
Viesti Kirjoittaja Oloffi »
Det kan vi inte göra, ni måste komma hit :P
Didn't mean it.
Samperi 3km from Sweden
HoleshotHolset
Viesti Kirjoittaja HoleshotHolset »
I have joined on the Swedish Mercedes forum.
I have an addiction to diesels 8) ...and I am a member of many forums:
Turbo Diesel Register
TDIClub
VWDiesel.net
Schuman Automotive (home of US Mersu SuperTurbo forum!)
Mersuforum
Holy Smoke Diesel
..and now Mercedes Forum Sverige - once I can successfully login...it is misbehaving at the moment when I attempt to login. :?:
Cheers,
Matt
'94 Dodge Ram 2500 - 12-valve Cummins - ~400hp at the rear wheels
'98 VW Beetle TDI - modified a bit
'00 VW Jetta TDI - wife's car (not modified much)
'96 Jeep ZJ - 3.9L common-rail Cummins / Allison LCT-1000 project vehicle
Walk-behind Ariens snowblower with 296cc 5.5hp direct injection diesel (has exhaust stack)
