Quick tour around the car. http://www.youtube.com/watch?v=L-qW-PpPYy0
Some easy driving. Barely 1/3 throttle application. http://www.youtube.com/watch?v=cxAxmbDKzNY
Full output.
http://www.youtube.com/watch?v=3RhAKbmClIA
Just playing around with it a bit. http://www.youtube.com/watch?v=19BjRqvnAi0
Notes-
I cut a bead on the stock intake manifold to keep the tube in place.
The turbo works great as a warmup exhaust restriction (I can see this becoming a problem in the summer).
There is about 2psi of exhaust pressure and just a *hair* off the peg of boost at idle.
There is almost no boost drop between shifts.
EGT's still run in the same ranges. I can easily pass 1250*f.
Decelerating from highway speeds maintains about 6 psi of boost all the way down to 30mph in 4th gear.
The turbo seems hover in the 10psi boost and 10psi exhaust pressure most of the time I'm moving under load.
Boost stays around 8psi : 10psi cruising the highway between 55-75mph.
Max boost is about 11psi below 3500rpm and peaks at 14psi by 4500rpm.
Exhaust pressure at 14psi boost is 20psi. 5psi less than the KKK K26 turbo.
Exhaust pressure can pass 30psi on a hard takeoff and free (no-load) revving.
I will concede that the GT22V is too small for an OM617. EGT's are still excessive at full load.
My main concern is the high initial exhaust pressures (Pegs my 30psi exhaust gauge). I'm worried that it can float the exhaust valves. Does anyone know at what psi the OM617 exhaust valves will lift off their seats?
