OM603 turbo exhaust manifold
Hi, I'd like to know how much a stock Euro-spec OM603 turbo exhaust manifold would cost, including shipping to the USA. Does anyone over there have one of these available?
A US-spec manifold cannot accept larger turbos, due to its complicated plumbing for a trap oxidizer. It's my understanding that a Holset HX 35 or similar turbo can be bolted up to the T3 mount on the stock Euro manifold.
Yes, I'm aware that a tuned header is superior, but I'm trying to upgrade in stages that my budget can absorb. I'm planning a Myna pump upgrade in the near future, so I'm just trying gather the parts at this time.
Kiitos
Kiitos
Casey
'87 300TD w/606
'90 300D 2.5t
'94 100CSQ Avant
'89 Transporter Bluestar
'87 300TD w/606
'90 300D 2.5t
'94 100CSQ Avant
canonballman
- Sisäänajossa
That is what Nokileka (I believe) said to me about an om603 manifold.Maybe HX35W or Schwitzer S2BG (fits directly to stock exhaust manifold) would be more practical solution. 250hp can be done with HX40, but general driveability won't be the best available. S2 is enough for 350hp with 60mm turbine wheel...
- HoleshotHolset
- Sisäänajossa
Re: OM603 turbo exhaust manifold
Deleted questions because I found this info: http://www.mercedesshop.com/Wikka/OM617CalToFedZeitgeist kirjoitti:A US-spec manifold cannot accept larger turbos, due to its complicated plumbing for a trap oxidizer. It's my understanding that a Holset HX 35 or similar turbo can be bolted up to the T3 mount on the stock Euro manifold.
Man - that California emissions manifold is NASTY looking!
Once I finally get around to gathering up parts for my future Mercedes diesel project(s), I plan on making my own manifold with a custom cut head flange, common plumbing fittings called 'weld ells' and a standard T3 weld flange that are readily available online from various places.
Thanks,
Matt
'94 Dodge Ram 2500 - 12-valve Cummins - ~400hp at the rear wheels
'98 VW Beetle TDI - modified a bit
'00 VW Jetta TDI - wife's car (not modified much)
'96 Jeep ZJ - 3.9L common-rail Cummins / Allison LCT-1000 project vehicle
Walk-behind Ariens snowblower with 296cc 5.5hp direct injection diesel (has exhaust stack)
- Forced_Induction
- Viesti:
Find a W140 3.5L engine. They use a non-trap manifold.
1982 300D
Maxed MW-Pump, Holset HE221W, straight pipe exhaust, A/W intercooler, W/M injection
W115 300D intake manifold, 2-Micron Baldwin BF7591-D fuel filter, W126 Gen-II front brakes
Webasto TSL-17 auxiliary hear, Battery relocated to the trunk, Factory skidplate, 15mm rear sway-bar
147HP, 220lb-ft at the rear wheels
2006 Honda Rebel Turbo Diesel
Kubota OC95, VZ21 turbocharger, Intercooler, Comet 40C/44D CVT
Also, the 603.971 USA engine has an EGR port. If you don't want one, you need to obtain a Euro-spec 603.9xx manifold instead...
Dave M.
Boise, Idaho, USA [size=84]
1995 E420 (New Arrival)
1995 E420 (W.I.P.)
1994 E500 (Q-ship)
1992 500E (Mach 5)
1987 300D (Sportline Stage 2)
Click here for my website [url=http://www.w124performance.com/images/]photos[/url], [url=http://www.w124performance.com/docs/]documents[/url], and [url=http://www.w124performance.com/movies/]movies[/url].[/size]
1995 E420 (W.I.P.)
1994 E500 (Q-ship)
1992 500E (Mach 5)
Hi, it is very complicated to find some. There is not a lot OM603.960 around.
I was shocked as well how your California EGR manifolds looks like.
Try german ebay sometimes they have some turbo diesel parts, but to be honest all parts for OM603 are quite rare.
I think that the best way is to make your own one. The factory mercedes exhaust manifolds have two parts connected together by clips.
And the pipes are terribly curved so another reason to make a custom ones
I took me a lot of time to find my engine in relatively good condition and I had to take whole car.
Good luck mate
Good luck mate
