Mercedes-Benz 300 ce 24v 1991
jorkka
Viesti Kirjoittaja jorkka »
Tuli tässä ostettua tuollainen, autoa ostaessa yllätyin varusteiden paljoudesta. Katsoin nettiautosta 90-luvun alun samanlaisia ce:tä, en ainakaan löytänyt montaakaan varustetta mitä ei tuossa omassa koslassa olisi... Joten voiko olla mahdollista että siihen olisi otettu lähes kaikki varusteet :?: :!:
Tässä lista varusteista valmistenumeron perusteella:
Options:
- 240 outside temperature indicator (с 01.03.1982)
- 241 left front seat electrically adjustable with memory feature. only applicable to w 210 when installed in conjunction with code 275. (с 01.03.1983)
- 242 right front seat electrically adjustable with memory feature. only applicable to series w 210 when installed in conjunction with code 275. (с 01.03.1983)
- 281 trunk set, (280 SL)
steering wheel with sports design (390 mm dia.) and gearshift lever in leather trim (с 01.05.1990)
steering wheel (390 mm) with sports design (с 01.03.1989)
- 291 airbag for front passenger
airbag for driver and front passenger (с 01.07.1987 по 30.09.1993)
airbag for driver and front passenger (if driver airbag standard - then only for passenger)
- 301 storage box in the rear (с 01.05.1988)
- 310 antenna with splitter for car phone net C, on left rear fender (с 01.02.1986)
antenna with splitter for car phone net C, on left rear fender; s 124, on right rear fender
- 412 electric sliding roof with tilting device (с 01.07.1983)
- 425 5-speed automatic transmission (с 01.02.1988)
- 430 headrests in the rear (с 01.01.1977)
- 443 tempomat (cruise control), and steering column, electrically adjustable (с 01.07.1984)
- 452 two-tone horn (с 01.01.1963 по 28.02.1993)
- 471 acceleration skid control (ASR) (с 01.07.1984)
- 544 roller blind, electric, for rear window and sun visors with vanity mirror on the left and right, illuminated (с 01.05.1985)
- 551 anti-theft warning system (с 01.11.1978 по 31.03.1998)
- 581 automatic climate control (с 01.01.1977)
- 600 headlamp wiper/washer (с 01.08.1971)
- 620 emission control system
vehicles with catalyst technique (с 01.03.1985)
- 653 sports chassis with 8-hole light alloy rims (с 01.01.1990)
- 673 high-capacity battery (с 01.01.1964)
- 873 seat heater for left and right front seats (с 01.02.1984)
- 915 fuel tank, 70 liter (с 01.05.1988)
Re: Mercedes-Benz 300 ce 24v 1991
jorkka kirjoitti: Joten voiko olla mahdollista että siihen olisi otettu lähes kaikki varusteet :?:
Lähes kyllä, mutta ei läheskän kaikkia :-D. Mm. tasonsäätö, aktiivibassokaiutinjärjestelmä, vetokoukku, poistumisvalot, polttoainelämmitin, Reiserechner, jääkaappi tavaratilassa puuttuvat.
Mutta poikkeuksellisen hyvin varustellusta autosta on joka tapauksessa kyse. Suomiautosta tuskin on kyse.
jorkka
Timo L. kirjoitti: Lähes kyllä, mutta ei läheskän kaikkia :-D. Mm. tasonsäätö, aktiivibassokaiutinjärjestelmä, vetokoukku, poistumisvalot, polttoainelämmitin, Reiserechner, jääkaappi tavaratilassa puuttuvat.
Ois se jo pitäny tietää, että ne myi mulle taas jonku karvalakkimallin... :D
Miten pystyn elämään ilman jääkaappia ja aktiivibassokaiutinjärjestelmää, sekä muita erittäin tärkeitä varusteita.
On (yllättäen) tuontiauto, tuotu kylläkin Suomeen jo vuonna Olavi Virta.
Mitä tuo "Reiserechner" tarkoittaa? :oops:
Wikke
Viesti Kirjoittaja Wikke »
jorkka kirjoitti:Mitä tuo "Reiserechner" tarkoittaa? :oops:
Se tarkoittaa suoraan käännettynä matkanlaskinta, nykyään kutsutaan nimellä ajotietokone :D Milloin tuo Reiserechner tuli lisävarustevalikoimaan? Vanhemmissa Mersuissa erittäin harvinainen varuste...
1991 420 SE
Wikke kirjoitti:Milloin tuo Reiserechner tuli lisävarustevalikoimaan? Vanhemmissa Mersuissa erittäin harvinainen varuste...
SA 245 on ollut saatavana ainakin syyskuusta 1985 lähtien, ei kuitenkaan ennen v. 1985. Kuvassa tyypissä W126, käyttökatkaisimet ovat keskikonsolissa sähkölasien nappien välissä.
HVM
Hupimestari
Hupimestari
Viesti Kirjoittaja HVM »
Wikke kirjoitti:
Oisko tuon regzwebegdtzderin voinu kertoa suoraan selkokielellä? :lol: Ei nimittäin aukea 99,7%:lle ihmisistä. :wink:
Wikke
HVM kirjoitti:
Wikke kirjoitti:
Eikö HVM tiedä mitä ajotietokone tarkoittaa? :wink:
1991 420 SE
JKL
Viesti Kirjoittaja JKL »
jorkka kirjoitti:Tuli tässä ostettua tuollainen, autoa ostaessa yllätyin varusteiden paljoudesta. Katsoin nettiautosta 90-luvun alun samanlaisia ce:tä, en ainakaan löytänyt montaakaan varustetta mitä ei tuossa omassa koslassa olisi... Joten voiko olla mahdollista että siihen olisi otettu lähes kaikki varusteet :?: :!:
Mitä maksoit? 8)
MB 300CE 24V
MB ML320
jorkka
JKL kirjoitti: Mitä maksoit? 8)
Sopivasti... :wink:
Missä hinnoissa teidän mielestä tuollaiset 24v 300 ce:t liikkuvat?
Mitä nyt katselin nettiautosta noita PYYNTIhintoja (9500-15000€), niin huh huh... :shock:
En minä ainakaan maksaisi 15 vuotta vanhasta autosta jotain 13000 euroa...
JKL
jorkka kirjoitti:
Sopivasti... :wink:
Minä hain Saksasta ja n. kuukauden etsinnän ja n. 50 auton jälkeen selvisi että täysin varustellut huippuyksilöt ovat kiven alla ja hinta kipuaa näissä yksilöissä sielläkin 7-9t€ huitteille! Niitä loppuunajettuja tuning- katiskoita oli sitten tonnista ylöspäin... 8)
MB 300CE 24V
MB ML320
JKL
Timo L. kirjoitti:
Mites nahkasisustus :shock: ?
MB 300CE 24V
MB ML320
JKL kirjoitti:
Timo L. kirjoitti:
Tere, sisustushan on yleensä omalla koodillaan ilmoitettu. Kun saatavilla on ollut kangas-, Karo-(ruudukas), MB-Tex-, veluuri- ja nahkavaihtoehdot kerrottuna useilla värivaihtoehdoilla, niin sisustusta ei yleensä lasketa varsinaisten varusteiden joukkoon.
jorkka
JKL kirjoitti:Mites nahkasisustus :shock: ?
Virheettömässä kunnossa oleva musta nahkasisusta.
JKL
jorkka kirjoitti:
vaikuttaa löydölle siis, onnea sen johdosta :D
MB 300CE 24V
MB ML320
