Viesti
Kirjoittaja Melitos »
Here goes:
On the left the pump is from w123, as it says in the picture, on the right the pump is from w124 without ELR.
First text:
Idle fine tuning
Second text
Idle coarse tuning.
-CCW decreases idle rpm.
- Should be adjusted ~same amount of degrees as full load
Third text:
Max RPM
- CW increases
Fourth text:
Full load fueling
- CCW increases
- 10% per turn
So long, and thanks for all the fish
