W205 220C Disel ja vikakoodeja vaikka muille jakaa
Kimboo
Viesti Kirjoittaja Kimboo »
Moottorin varoitusvalo syttyi käynnistyksen yhteydessä, luin vikakoodit ja lista olikin melkoinen, joten kellään ideaa mikä voisi aiheuttaa näin monta vikaa saman aikaisesti? Auto toimii täysin normaalisti, ainoa mitä olen huomannut on että Adblue määrää ei sustu mittaamaan.
Tässä lista: :wtf:
Olisiko joku johto/liitin vika tai ECU ?
============1==============
U0101(FA)
Raw code: C101FA
ECU: 7EA[Archive (inactive)]
Status: Pending, Confirmed
OBDII: Data bus, transmission control module (TCM) - no communication
Mercedes-Benz: Lost Communication with TCM
============2==============
U0101(FF)
Raw code: C101FF
============3==============
U105C(FC)
Raw code: D05CFC
============4==============
U045A(E3)
Raw code: C45AE3
OBDII: Invalid data received from parking aid control module A
============5==============
U1444(E1)
Raw code: D444E1
============6==============
U0100(FA)
Raw code: C100FA
OBDII: Data bus, engine control module (ECM) A - no communication
Mercedes-Benz: Lost Communication with ECM/PCM A
============7==============
U0100(FD)
Raw code: C100FD
============8==============
U045A(E2)
Raw code: C45AE2
============9==============
C053B(FE)
Raw code: 453BFE
============10==============
U105C(FB)
Raw code: D05CFB
============11==============
U105C(FA)
Raw code: D05CFA
============12==============
U045A(FF)
Raw code: C45AFF
============13==============
U045A(FB)
Raw code: C45AFB
============14==============
U045A(E0)
Raw code: C45AE0
============15==============
U045A(FD)
Raw code: C45AFD
============16==============
U045A(FC)
Raw code: C45AFC
============17==============
U045A(E5)
Raw code: C45AE5
============18==============
U0420(E1)
Raw code: C420E1
OBDII: Invalid data received - power steering control module
============19==============
U0420(E0)
Raw code: C420E0
============20==============
U0420(FF)
Raw code: C420FF
============21==============
P068B(00)
Raw code: 068B00
ECU: 7ED[Archive (inactive)]
Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear
OBDII: Engine control (EC) relay - shut-off delay
============22==============
U0164(87)
Raw code: C16487
Status: Confirmed, Test failed since last DTC clear
OBDII: Data bus, AC control module - no communication
============23==============
P008A(00)
Raw code: 008A00
ECU: 7EB[Archive (inactive)]
Status: Pending, Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle
OBDII: Low pressure fuel system - pressure too low
============24==============
P0627(00)
Raw code: 062700
Status: Test failed since last DTC clear
OBDII: Fuel pump (FP) control - open circuit
============25==============
U0155(31)
Raw code: C15531
ECU: Transmission control unit[Archive (inactive)]
Status: Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear
OBDII: Data bus, instrumentation control module - no communication
============26==============
P0606(00)
Raw code: 060600
OBDII: Engine control module (ECM)/powertrain control module (PCM) - processor fault
Mercedes-Benz: PCM Processor Fault
============27==============
U0126(00)
Raw code: C12600
OBDII: Data bus, steering position sensor control module - no communication
============28==============
U0146(00)
Raw code: C14600
OBDII: Data bus, gateway A - no communication
============29==============
U0121(00)
Raw code: C12100
Status: Test failed (current drive cycle), Pending, Test failed since last DTC clear
OBDII: Data bus, anti-lock brake system (ABS) control module - no communication
============30==============
U0100(00)
Raw code: C10000
Status: Pending, Test failed since last DTC clear
============31==============
U0141(00)
Raw code: C14100
OBDII: Data bus, body control module (BCM) A - no communication
============32==============
P042F(71)
Raw code: 042F71
ECU: Engine control unit[Archive (inactive)]
OBDII: Exhaust gas recirculation (EGR) valve actuator A - actuator stuck closed
============33==============
P2463(09)
Raw code: 246309
OBDII: Diesel particulate filter (DPF) - DPF restricted
============34==============
P0336(64)
Raw code: 033664
OBDII: Crankshaft position (CKP) sensor - range/performance problem
============35==============
P13E7(FD)
Raw code: 13E7FD
============36==============
P220F(77)
Raw code: 220F77
============37==============
P220E(77)
Raw code: 220E77
============38==============
P229F(91)
Raw code: 229F91
Status: Test failed, Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle
OBDII: Nitrogen oxides (NOx) sensor 2, bank 1 - circuit range/performance
============39==============
P204F(96)
Raw code: 204F96
OBDII: Reductant system, bank 1 - performance problem
============40==============
P13DF(09)
Raw code: 13DF09
Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear, Warning indicator requested
============41==============
P1403(00)
Raw code: 140300
OBDII: DPFE Sensor Hoses Reversed
============42==============
P20B9
Raw code: 20B9
ECU: 7EC
Status: Pending
OBDII: Reductant heater control A - open circuit
============43==============
P20BA
Raw code: 20BA
ECU: 7EC
Status: Pending
OBDII: Reductant heater control A - circuit performance problem
============44==============
P13DF
Raw code: 13DF
Status: Pending
============45==============
P20B9
Raw code: 20B9
ECU: 7EC
Status: Confirmed
============46==============
P13DF
Raw code: 13DF
Status: Confirmed
Re: W205 220C Disel ja vikakoodeja vaikka muille jakaa
Testeriin vaan...oikeaan testeriin.
amatoori
Viesti Kirjoittaja amatoori »
Tollasen nipun tallentuneita vikakoodeja voi aiheuttaa vaikkapa yksi pakkaskäynnistys vajaalla akulla. Ja just niinkuin dealer kirjoitti, siihen oikeeseen testeriin, eli stariin.
Kimboo
Ok, joo huomenna olisi tarkoitus viedä, mutta pitääkö olla huolissaan?
TPLtre
Viesti Kirjoittaja TPLtre »
Ei pidä. Pitkä lista ei tarkoita sinänsä mitään. Näyttää että jännite käynyt alhaalla ja vähän joka paikasta herja siitä, mutta eihän nuo ole mersun vikakoodejakaan. Starin piuhaan, vikakoodien nollaus ja sitten katsellaan tuleeko uusia.
Tuliko nuo kuitakusen jälkeen heti takisin
Kimboo
CDI203 kirjoitti: Su 07.02.2021 19:59 Tuliko nuo kuitakusen jälkeen heti takisin
Joo tuli, mutta siis tollaisella odb2 lukijalla, ei starilla vielä yritetty.
Kimboo kirjoitti: Su 07.02.2021 21:09
Jos tulee vielä senkin jälkeen niin sitten saurailla sen antamia tarkistus ohjeita
TPLtre
No jos nuo kaikki pitäisi paikkansa niin ei sillä autolla enää ajettaisi. Yleistesteri ei nyt vaan pysty.
Kimboo
Näin vähän ajattelin, et tuolla listalla varmaan pitäisi jotain huomata. Toki toi adblue tankin tason mittaus ei skulaa. Ilmoittaa vain, että ei voi mitata.
St bertils
Viesti Kirjoittaja St bertils »
:thumbup: Ihan normi,auto kuivatukseen lämpimään ja puhaltimet sisään ni kunnos...
Kimboo
Tänään kävi auto Veholla ja ongelmaksi selvisi adblue putken vastusvika. Eli adblue päässyt jäätymään. Osa+työt 700€ ja huomenna arvio koska osan voisi Saksan maalta mahdollisesti saada.
Kimboo
DBFI kirjoitti: Ma 08.02.2021 19:06 Siis tuo 140 Euron osa:
https://mercteil.com/product/spare-part ... 2054700900
Ilmeisesti juuri tuo.
Kimboo
Onko kenelläkään kokemusta kannattaisiko koko Adblue järjestelmä ohjelmoida pois, ilmeisesti sekin vaihtoehto on.
Hifis
Viesti Kirjoittaja Hifis »
Kävi itsellä eilen illalla tää sama case, käväsin viikonloppuna pohjanmaalla sukuloimassa ja alla tosiaan 2015 E 220 d 4matic. Ajelin Mesellä sen 1000km edes takasin ja pääsin 3km päähän kotiovesta ennen ku vikavalo sytty. Nyt käväsin motomaatilla lukasemassa koodit ja heitti juurikin P220f vikakoodin. Juteltiin motomaatin gaiffarin kanssa, niin sano että veikkaa NOX anturia että se on paskana. Ollessani Romuxilla töissä sen parisen vuotta niin oli pari casea tuli vastaan, jossa olin myyny asiakkaalle C 250 d jolla oli ajettu alle 100tkm ja NOX-anturi paukku saman tien. Kyseisen vian kunnostaminen oli jossain 1200-1300€ välissä. Toisaalta itellä ollu kyllä tiedossa että näissä koneissa toi anturi on tyyppivika ja on menny monissa kikkareissa jo 5tkm kohallaki. Aattelin nyt ite korjaamolta kysästä kustarin ja laittaa autoliikkeen suurimmaks maksumieheks, koska auto hankittu muutenki 4kk sitten ja ajettu vasta 133tkm. Suosittelen muita toimimaan myös näin jos kyseinen vika kohdalle osuu.
Toki suosittelen käyttämään korjaamolla vielä varmistamassa onko tosiaan kyseinen vikakoodi nimenomaan edellä mainittu. Monesti kyllä tarkottaa tota anturia.
W124 E 200D
W205 C 250D 4matic
W203 C 180
W212 E 220D 4matic
