500bhp drift project
mantahead
Viesti Kirjoittaja mantahead »
hi friends,
hope this is in right section, sorry i don't speak finnish.
i'm building a w202 with om606, eaton m112 charger and hx52w turbo.
last time i had w202, om605, holset hx35 running 385bhp on original modifed exhaust manifold. Dieselmekens' first 7.5mm m- pump.
here is small clip
http://www.youtube.com/watch?feature=pl ... GITi-n9ZTU
some clips from drift and drag.
http://www.youtube.com/watch?feature=pl ... Mhdp_c4c5w
http://www.youtube.com/watch?feature=pl ... yNYdXWnK0s
edited tried to embed videos.
Viimeksi muokannut mantahead, Ma 29.07.2013 01:46. Yhteensä muokattu 5 kertaa.
mantahead
Re: 500bhp drift project
some pics,
old car,
new car,
looked in the yard for strong rear axle.
mantahead
supra front shocks,Kuva
modify to rears
mantahead
eaton m112
tomant
Viesti Kirjoittaja tomant »
Hi and welcome ro Mersuforum.net! Nice to see a W202 car here among the many w124 and w201 cars.
This section is OK, you could post on the Turbot section or the English forum section, too. I believe the turbo freaks mostly read the Turbot section and this one. There are a few drifting cars shown here and a lot of other "hobby racers".
tomant
pera8x
Viesti Kirjoittaja pera8x »
nice job!
W201 250DT 20V
ssuvik
Viesti Kirjoittaja ssuvik »
Nice project 8) Where do you live?
E350CDI&A180CDI
mantahead
hi,
thanks,
I'm from Ireland.
sorry about the pictures, i need to fix my photo bucket
mantahead
hi,
do any of you guys use Dieselmeken 8mm pump?
pera8x
Hi. I guess no. Here in finland we have corporation named by mynädiesel. mynädiesel makes the best pumps around the world as far as I know. Has won lots of a tractorpulling things etc..
if you want a really good pump to your engine, I suggest you to take a contact to this dieselpump expert mynädiesel. I guess this company can delivery ready pump to you at a home. I don't know the price, but you can ask it by your self.
somebody will give you all connection information to the mynädiesel. I don't know these things.
good luck to you whit perfect diesel injection pump!
W201 250DT 20V
mantahead
hi Pera8x,
thanks for that, i tried to contact Myna a few years back with no luck, but then i met Goran,( Dieselmeken) from Sweden,
he helped me out with my last pump for the om605, it was high rpm 7.5mm, 150cc.
I was happy with it, so i think i will try his new 8mm, he has modified cam in some of his new 8mm.
No one in Ireland here, can do much magic with these pumps.
Paabeli
Viesti Kirjoittaja Paabeli »
Herlevi is good and Mynädiesel. And Siekkinen from Kalajoki Finland do best gearbox
S124 OM606 ST
EX W123 200D
EX W124 200D
EX W202 220D
EX S124 300TDT
EX S124 300TD
kasiässä
Viesti Kirjoittaja kasiässä »
http://www.herlevi.fi/tuotteet.htm" onclick="window.open(this.href);return false; Pumps up to 18mm.... :wave:
mantahead
some work on the cage.
mantahead
steering quickener, not sure how it will work with steering box but i will give it a go, its 2:1 ratio.
mantahead
hi,
i got my gearbox built back up and ready for in, so i can make up the mounting bracket.
-Yamatec-
Viesti Kirjoittaja -Yamatec- »
Intresting project! Keep it up :thumbup:
W210 E300DT -97 Käyttis
W201 190 Om605 St-Projekti
hismajestics
Very nice build with interesting details. What vehicle does the rear axle come from?
Welcome to the forum, btw :D
//johannes
250CE -72 M104 3,2L
mantahead
thanks
toyota supra twin turbo
mantahead
got the gearbox mount made up,
mantahead
Experimenting with the turbo and 4 inch down pipe before i make the tubular manifold, not so much room on right hand drive for big downpipe.
runner number 6 will be close.
turbo will have to go low, and manifold high, to let downpipe under manifold.
hismajestics
Interesting :) I was of the understanding that a steering quickener is for rack & pinion setup but i guess it depends on where you bolt it up. Wouldn't it work when bolted to the steering column?
//johannes
250CE -72 M104 3,2L
hismajestics
//johannes
250CE -72 M104 3,2L
mantahead
hi,
yea, i'm gonna try it and see what happens, steering is very heavy to turn with it in, so i won't know until i have engine running and power steering working.
in the picture its fitted the wrong way around to leave steering light for pushing car in and out of garage :D
steering column bits,Kuva
gearbox is from e39 530d or e46 330d
Exami
Viesti Kirjoittaja Exami »
Hope for the best that the GS5-39DZ can take the beating, if that fails, go for GS6-53DZ (BMW E60 530D's gearbox)
W201 - 1/4 Mile: 9.83 @ 238kmh
W108 - "Low"Rider
Malagutisti
Viesti Kirjoittaja Malagutisti »
Actually the GS6-53DZ/BZ gearbox can be also found from e46 330d and e39 530d if the have the M57N (201hp) engine.
GS5-39DZ gearbox was used in e46 330d/e39 530d with older M57 (181hp), so if this is one has 6 gears and is from a 3 liter engine, it's already the tougher one.
-e46
Exami
Malagutisti kirjoitti:Actually the GS6-53DZ/BZ gearbox can be also found from e46 330d and e39 530d if the have the M57N (201hp) engine.
M57N cannot be found from E39 in stock form as it was never made. in E46 that is possible in 2003 or 2004 models.. but its easier to search for the E60 gearbox as they all are from M57N or M57N2 (M57NTU).
i know these cause i own currently E46 330xd and i've owned E39 530d for a some time.
Anyway GS6-53DZ will stand whole alot more tourge than the GS5-39DZ..
W108 - "Low"Rider
mantahead
yea, its the 5 speed GS5-39DZ. Hopefully it will take the power.
Malagutisti
Exami kirjoitti:
Oh yes, you're right. I messed up the e39's M57D29 and M57D30.
The maximum input torque of these trannies is told on the type, GS6-53 holds up to 530Nm and GS5-39 390Nm :mrgreen: .
-e46
mantahead
hi,
i made a start on exhaust manifold, i had to mount the turbo low so the 4 inch downpipe could go underneath the manifold runners, remember this is right hand drive so the steering box is in the way.
Armagh-20130903-00544.jpg by mantahead, on Flickr
Armagh-20130903-00545.jpg by mantahead, on Flickr
tapered pipe comes through flange to start taper at head.
Armagh-20130912-00564.jpg by mantahead, on Flickr
Armagh-20130912-00567.jpg by mantahead, on Flickr
Armagh-20130913-00580.jpg by mantahead, on Flickr
Armagh-20130913-00585.jpg by mantahead, on Flickr
Armagh-20130913-00588.jpg by mantahead, on Flickr
Armagh-20130913-00586.jpg by mantahead, on Flickr
all runners are equal lenght, they are pretty long but its the only way i could do it to get the down pipe underneath.
its all tacked with the mig, now to the bench for the tig. :D
was gonna use stainless but got these bends so cheap :)
