Nyt tarvittaisi nokkien laakeripukkien kiristystiukkuusarvoa, onko kellään tietoa?
sedan124
W201 2.5 16V:n nokkien laakeripukkien kiinnitystiukkuus?
Re: W201 2.5 16V:n nokkien laakeripukkien kiinnitystiukkuus?
Olisiko tuo oikea vuosimalli kun en ollut varma
Tightening torques
Cylinder head instructions
Cylinder head
Maximum bolt length 105 mm
Stage 1 Tighten 55 Nm
Stage 2 Tighten 90°
Stage 3 Tighten 90°
Other tightening torques
Main bearings Renew bolts/nuts No
12 Main bearings Stage 1
Big end bearings Renew bolts/nuts No
Big end bearings Stage 1 40 Nm
Big end bearings Stage 2 90°
Sump drain bolt 25 Nm
Flywheel/driveplate 30 Nm+90°
Clutch to flywheel 25 Nm
18 Crankshaft pulley/damper centre bolt
Camshaft sprocket/gear 12 Nm
Camshaft carrier/cap 21 Nm
Camshaft/rocker cover 10 Nm
Spark plugs 20 Nm
25 Steering track rod end 35 Nm
25 Brake disc to hub Front 10 Nm
35 Brake caliper to carrier Front
37 Brake caliper carrier to hub Front
25 Brake disc to hub Rear 8 Nm
36 Brake caliper to carrier Rear
38 Brake caliper carrier to hub Rear
ABS sensor Front 22 Nm
25 ABS sensor Rear 8 Nm
Road wheels 110 Nm
Autodata Note 12
Main bearings
Manufacturer: Mercedes-Benz Model: 190 (201) 2,5 190E-16
Engine code: 102.990 Output: 150 (204) 6750
Tuned for: RUF Year: 1988-93
© Autodata Limited 2007
14.5.2012
V6.410-
M12 = 90 Nm
M11 = 55 Nm + 90°.
Autodata Note 18
Crankshaft pulley
Standard bolt = 300 Nm
Stretch bolt = 200 Nm + 90° + 90°.
Autodata Note 25
Use new nuts/bolts.
Autodata Note 35
Use new bolts and tighten to 35 Nm.
Autodata Note 37
Front carrier to hub
Use new bolts and tighten to 115 Nm.
Autodata Note 36
Use new bolts and tighten to 25 Nm.
Autodata Note 38
Rear carrier to hub
Use new bolts and tighten to 55 Nm.
14.5.2012
V6.410-
Tightening torques
Cylinder head
Stage 2 Tighten 90°
Stage 3 Tighten 90°
Spark plugs 20 Nm
Road wheels 110 Nm
Autodata Note 12
Main bearings
14.5.2012
V6.410-
M12 = 90 Nm
M11 = 55 Nm + 90°.
Autodata Note 18
Crankshaft pulley
Autodata Note 25
Use new nuts/bolts.
Autodata Note 35
Autodata Note 37
Autodata Note 36
Autodata Note 38
Rear carrier to hub
14.5.2012
V6.410-
Kiitokset Arskalle, mulla koneen tyyppi 102.991 mutta tuon 102.990:n arvot käyvät varmaan tuohon minunkin motoriin.Sedan124 kirjoitti:Nyt tarvittaisi nokkien laakeripukkien kiristystiukkuusarvoa, onko kellään tietoa?
sedan124
En usko että noissa momenteissa on eroja jos joku on eri mieltä niin varmaan kertoo
