Little introduction, i'm rico i'm 21 years old. Working as an mechanic in a local garage. I currently own a audi v8 4.2 nice car but i really love mercedes. And especialy the finnisch superturbo's
So i've made the decision to build one. I know i can build it myself. I have he knowledge an space to build one. But i need some help from the experts.
First question, can i use a n/a engine to covert it to an turbo engine? Whats the difference? There plenty om603 n/a avalable here. I know i probaly must fit oil jets to cool the pistons.
What the best option with the gearbox? Automatic are quiet strong i believe (stock) but could an stickshift and clutch hold up? Or should it be reïnforced?
Big issue is the pump. I've done some research to pumps. I want 7.0/7.5 mm plungers. I will be fitting them myself. Is there some webshop out there where i can buy them? I've read about firad plungers?
Whats the difference between a M pump and an MW pump? Wich one will i need? How about the adjustment? Whats the alda screw and what setup or adjustment will the rest of the pump need?
If i can't adjust it i'll take it to a friend who works at an bosch diesel service point. But i wana give it a try myself.
It wil be a little budget project, but if it all works out good then i'm going to scale the budget up.
I'll be fitting an hx40 and want about 250 horsepower. Any tips are also be appreciated. I understand english but not very good in an technical way.
Thanks and greetings from holland
