What is the best lift pump fuel pressure for an M-Pump?
Mine runs 12psi with the relief opening at 35psi using the primer pump.
If I were to use an electric fuel pump, is 35psi too much pressure for the pump to be fed constantly?
Lift pump pressure
- Forced_Induction
- Viesti:
Lift pump pressure
1982 300D
Maxed MW-Pump, Holset HE221W, straight pipe exhaust, A/W intercooler, W/M injection
W115 300D intake manifold, 2-Micron Baldwin BF7591-D fuel filter, W126 Gen-II front brakes
Webasto TSL-17 auxiliary hear, Battery relocated to the trunk, Factory skidplate, 15mm rear sway-bar
147HP, 220lb-ft at the rear wheels
2006 Honda Rebel Turbo Diesel
Kubota OC95, VZ21 turbocharger, Intercooler, Comet 40C/44D CVT
- Forced_Induction
- Viesti:
Re: Lift pump pressure
No love here?
1982 300D
- Forced_Induction
- Viesti:
Got a pump. Still no advice?
1982 300D
15psi is enough if you can keep it up all the time. There won't be any problem with stock elements but if you are using 8mm elements, electric fuel pump is needed. 35 psi isn't too much but it doesn't make any difference.
W211 4.0 CDI / om628
W202 2.5 TurboD / om605
W201 2.6E / m103
W201 2.6E / m103
