VIN-dekooderi eli mersusi varusteet alustanumerolla
Linkkejä Mercedes-Benz-aiheisille sivuille.
OK kiitos vastauksesta. Tuo lista näyttää jo oikeammalle. Voi olla, että systeemi on sekoittanut tuon värin (651) tarjoten sitä SA651:nä.
Hemmo
Viesti Kirjoittaja Hemmo »
Oma vaatimaton panokseni:
VIN WDB2021211A233885
Model C 220 DIESEL
Chassis 2021211A233885
Engine 604910 10 035768
Transmission 717416 06 721086
Order 0 3 290 42599
Lights VALEO
Cab 00000
Delivery date 18.01.95
Dealer company employees (290)
Interior fabric black / anthracite (701)
Paint
149 polar white (T) (с 01.01.1992)
Options
030 approved electronic saveguard against unauthorised removal (FBS 2) (с 01.10.1994)
287 ski inboard loading facility
through-loading feature (с 01.10.1990)
291 airbag for front passenger
airbag for front passenger (с 01.10.1993)
airbag for driver and front passenger (if driver airbag standard - then only for passenger)
412 electric sliding roof with tilting device (с 01.07.1983)
430 headrests in the rear (с 01.01.1977)
537 mechanically operated antenna and front loudspeaker - without radio set (с 01.10.1989)
591 heat-insulating glass, all-around, heated rear window pane, (single-sheet safety glass), Germany
green heat-insulating glass all round, heated rear window, single pane safety glass - Germany (с 01.01.1972)
959 equipment package esprit (с 01.11.1992)
W202 C220 D Esprit / Plymouth Roadrunner 440 / Buick Riviera Custom '67
Kari.S
Viesti Kirjoittaja Kari.S »
VIN WDB1241931F345304
Model 300 TD TURBODIESEL
Chassis 1241931F345304
Engine 603960 12 054748
Transmission 722357 04 240027
Order 0 5 229 21293
Lights HELLA
Wiper BOSCH
Delivery date 29.01.96
Dealer Stuttgart branch (229)
Interior fabric gray+slate gray+orion gray (008)
Paint
366 azurite blue metallic (с 01.01.1994)
228 auxiliary heater
auxiliary heater (с 01.11.1974)
auxiliary heater (only provision for installation in w 210)
249 automatically dipping inside rear view mirror (с 01.06.1990)
270 antenna for D net tel. on rear left fender with splitter and loudspea. (с 01.11.1992)
antenna with splitter on rear left fender (rear right fender of s/v 124) and loudspeaker for D-network telephone
289 wooden/leather steering wheel (dia. 390 mm)
wood-/leather steering wheel (ш 390mm) and leather gearshift (с 01.02.1993)
multiple contour backrest for right rear single seat
300 storage box in front tray (с 01.05.1988)
340 additional 3rd stop lamp (с 01.10.1989)
341 additional lamp (с 01.09.1982)
440 tempomat (cruise control) (с 01.09.1975)
512 radio Becker Europa cassette
radio MB Special with traffic news decoder (VK), with RDS (с 01.07.1992)
541 double roller blind used as luggage and passenger guard (с 01.01.1980)
550 trailer coupling (с 01.03.1965)
551 anti-theft warning system (с 01.11.1978 по 31.03.1998)
570 folding armrest front w202/210 stowage box front with armrest (с 01.04.1970)
front folding armrest w202 - housing at front with armrest
581 automatic climate control (с 01.01.1977)
584 electric window lifters (front and rear doors) (с 01.04.1970)
electric window lifters, fourfold or sixfold
600 headlamp wiper/washer (с 01.08.1971)
611 courtesy lamps for front and rear doors, with W124 also for central doors/W202 front doors only (с 01.11.1978)
620 emission control system
vehicles with catalyst technique (с 01.03.1985)
645 M+S tires (с 01.10.1963)
682 fire extinguisher (с 01.04.1970)
731 wood trim, burred walnut root (с 01.08.1980)
882 passenger compartment protection/towing-off protection (with anti-theft warning system only) (с 01.07.1993)
885 locking system with infrared remote control and immobilizer (с 01.10.1993)
880 - with immobiliser
980 vehicle registration book
vehicle registration book and general operating permit no. on type plate for export vehicles (с 01.08.1980)
Henri_L
Viesti Kirjoittaja Henri_L »
Tässä tosta omasta jotain.
auto s211 280cdi-07
Code Текст
110 Unknown
197U OBSIDIAN BLACK - METALLIC PAINT
202B OWNERS MANUAL AND SERVICE RECORD - GERMAN
213 PARAMETER STEERING
220 PARKTRONIC SYSTEM (PTS)
229L STUTTGART BRANCH
250B Unknown
260B Unknown
280 LEATHER STEERING WHEEL AND LEATHER GEAR SHIFT KNOB
287 THROUGH-LOADING FEATURE
2XXL FEDERAL REPUBLIC OF GERMANY
340A Unknown
341A Unknown
354 ANTENNA FOR TELEPHONE D/E-NET
386 Unknown
404 MULTI-CONTOUR SEAT, FRONT LEFT
427 AUTOMATIC TRANSMISSION 7-SPEED
443 Unknown
474 PARTICLE FILTER
477 Unknown
527 Unknown
543 SUN VISOR WITH MAKE-UP MIRROR L. AND R., BE-
581 AUTOMATIC AIR CONDITIONER
600 HEADLAMPS - CLEANING EQUIPMENT
614 Unknown
619 XENON LIGHT UNIT - HEADLAMP DISCONTINUED
673 HIGH-CAPACITY BATTERY
690 Unknown
734 Unknown
807 AEJ 06/1/M/X
910 DYNAMO WITH HIGHER CAPACITY (FFO)
915 FUEL TANK WITH LARGER CAPACITY
926 AIR POLLUTION CONTROL D4 EU4-MEASURES
953 Unknown
985 Unknown
K11 Unknown
K12 STEUERCODE FUER SERVICEINTERVALL
K13 Unknown
M30 DISPLACEMENT 3.0 LITER
P78 Unknown
P80 Unknown
Q24 Unknown
R01 Unknown
R75 Unknown
U12 Unknown
341A Unknown
Tesla Model 3
Ex C300 blueTec hybrid S205
Ex e300 blueTec hybrid s212 facelift
EX 280cdi v6 S211
EX 220 cdi S203
EX 290 TD W210
EX. 250D W124
Macc
Viesti Kirjoittaja Macc »
Näyttää olevan alhaalla tuo sivu, niin osaakos joku tulkata sieltä missä vika, vai onko kokonaan poistunut keskuudestamme?
nj^
Viesti Kirjoittaja nj^ »
translate.google.fi kertoo että "Vin dekooderi ei ole tällä hetkellä saatavissa"
korvaavaa tietoa
W211
Vanhat:
tols
Viesti Kirjoittaja tols »
Osaako joku kertoa tarkemmin "H12 Hot water additional heater" lisävarusteesta. Lieneekö lohkis/webasto?
Aurinkoinen
Re: VIN-dekooderi
Viesti Kirjoittaja Aurinkoinen »
341 ADDITIONAL BLINKER LAMPS
466 Unknown
482 SPRINGS FOR HIGHER GROUND CLEARANCE
524 PAINTWORK - PRESERVATION
593 ALL-ROUND WD-GREEN GLASS,HEATED REAR WINDOW-ESG,BF
620 AIR POLLUTION CONTROL
630 ECE - WARNING TRIANGLE
668 PACKAGING FOR SHIPPING VEHICLES WITH TIE-DOWN HOOK
802 AEJ 06/1/M/X
040 C 220 CANADA SPECIAL EDITION
067 Unknown
Lieköhän tuo 040 C 220 CANADA SPECIAL EDITION väri vai mikä?
W124 200D -92
C124 230CE
Re: VIN-dekooderi
Aurinkoinen kirjoitti: 040 C 220 CANADA SPECIAL EDITION
067 Unknown
Nämä dekooderit - mukaanlukien Mersun oma EPC/WIS - laittavat värin ja verhoilun vielä tuohon varusteluettelon päätteeki, vaikka niille olisi ollut oma rivi jo ylempänä. Eli jos autosi on normaali musta, se tarkoittaa väriä. 067 on taas verhoilu.
ape86
Re: VIN-dekooderi
Viesti Kirjoittaja ape86 »
jos joku viitsis kaivaa autoni tiedot niin kiitän! :!:
WDB2020281A295997
aadolf
Re: VIN-dekooderi
Viesti Kirjoittaja aadolf »
tuommosta tietoo anto itänaapurin sivusto
fin
vin WDB2020281A295997
whc WDB
chassbm 202028
chass_ident 1A295997
type 202
subbm1 028
subbm2
auxiliary_drive
body 00000
body_code
delivery_date
engine 104941 10 005587
front_axle1
front_axle2 BE1150S1998220941244
heater 0-20309094
interior 707A
lights VALEO
model_idx 11
odometer
order_num1 0520370037
paint1 199
paint2
paint3
paint4
paint5
platform
production_num1
production_order_ref
rear_axle1
rear_axle2
release_date
retarder 1 950516
rims
service_num
steering
trailer
transfer_case
transmission 717441 06 699765
vin_dc
vinwhc
winch
wiper
Code Текст
048 BR202 NEW INSTRUMENT PANEL FOR AIRBAG PASSENGER SI
282 SKI-BAG
291 AIRBAG FOR FRONT PASSENGER
412 Unknown
515 MB RADIO CLASSIC WITH TRAFF. MESS., RDS
570 FOLDING ARMREST, FRONT
591 Unknown
959 EQUIPMENT PACKAGE ESPRIT
199 APPLICATION CODE FOR COMPONENT PROCESSING
707A Unknown
W166 350 bluetec
S211 270cdi
W126 280s
Re: VIN-dekooderi
aadolf kirjoitti:tuommosta tietoo anto itänaapurin sivusto
Taas iski foorumin "sensuuri" (lähetettyjä viestejä selvästi katoaa jotenkin silloin kun joku muu on kommentoimassa threadia samaan aikaan) kun urputin viestissäni sitä miksi foorumilaiset eivät itse viitsi klikata hiirellä pari kertaa ja lukea noita venäläisten sivuja. Veikkaan että iskee laiskuus lukea threadia pari viestiä taaksepäin sen linkin löytämiseksi.
Vähän eri juttu jos tuo venäläisten lista ei kelpaa (huonot "käännökset" koodeille) tai jos omaa autoa ei löydy listalta (esim. liian uusi).
http://www.auto-parts.spb.ru/cat/cats/m ... ent=dr2000" onclick="window.open(this.href);return false;
sarkki
Re: VIN-dekooderi
Viesti Kirjoittaja sarkki »
DBFI kirjoitti:
Ite olen kokeillut tuota linkkiä käyttää mutten saa kun tyhjä sivu kun ole naputellut VIN-koodin sisään! Mun VIN-koodi mitä olen laittanut on WDB1231201A151262 Mitäköhän teen väärin?
vito mallia karvalakki 108 cdi -99 (käyttis)
s124 300TD -92 (odotus vaiheessa, ehkä myytävänä..)
actros 2546 -08 (työkalu)
s211 320 cdi -03
w210 290 turbodiesel -96
tj86430
Re: VIN-dekooderi
Viesti Kirjoittaja tj86430 »
sarkki kirjoitti:
DBFI kirjoitti:
Naputtelet VIN koodin ja painat sitä vieressä olevaa nappia. Tulee sivu, jossa lista auton osajärjestelmistä. Painat oikeassa yläkulmassa olevaa DataCard-linkkiä, aukeaa uusi ikkuna jossa listattu mm. auton varusteet. Mikä kohta sinulla menee pieleen?
s213 220d -17
Villa Pikkujalo
Re: VIN-dekooderi
tj86430 kirjoitti: Naputtelet VIN koodin ja painat sitä vieressä olevaa nappia. Tulee sivu, jossa lista auton osajärjestelmistä. Painat oikeassa yläkulmassa olevaa DataCard-linkkiä, aukeaa uusi ikkuna jossa listattu mm. auton varusteet. Mikä kohta sinulla menee pieleen?
Yksi mahdollisuus olisi pop-up blocker, se kantakortti kun aukeaa pop-up ikkunana. Kohta varmaan kuullaan mikä oli oikea ongelma, tämä auto kuitenkin löytyy tietokannasta.
CDI203
Re: VIN-dekooderi
Viesti Kirjoittaja CDI203 »
DBFI kirjoitti:
yhtteen väliin kiukkuteli virustorjunnasta, tms luotettu sivusto asetuksista
ape86
Re: VIN-dekooderi
707A Unknown
mikähän tuo viimene mahtaa olla?
Jännä juttu kun auto pitäsi olla rekisteröity Brabukseksi, mutte sitä tietoa mistään löydy..
Re: VIN-dekooderi
ape86 kirjoitti:
707A Unknown
Onko tehtaalta lähtenyt yhtään Brabus-varusteltua mersua? Tuo ei ole rekisteriote vaan kantakortti.
sarkki
Re: VIN-dekooderi
tj86430 kirjoitti:
sarkki kirjoitti:
DBFI kirjoitti:
Kun VIN-koodi on syötetty ja sitä viereistä nappulaa painettu tulee esiin vain tyhjä sivu. Ainoa mitä sillä ikunalla voi painaa on se Mercedes Benz teksti siinä ylhäällä. Popup blockeri on pois päältä ja kun minä käytän Mac:ia niin virustorjuntaa ei ole! Pitäiskö kokeilla PC:tä
s211 320 cdi -03
Re: VIN-dekooderi
sarkki kirjoitti: Ainoa mitä sillä ikunalla voi painaa on se Mercedes Benz teksti siinä ylhäällä. Popup blockeri on pois päältä ja kun minä käytän Mac:ia niin virustorjuntaa ei ole! Pitäiskö kokeilla PC:tä
Siinä se taisi sitten tullakin. Se on hienoa jos virukset ei vaivaa vaikka sitten selain ei toimisikaan. :roll:
Tällainen sivu (tuossa alla) sieltä pitäisi tulla. Oletko kokeillut selata sitä tyhjää sivua vähän alaspäin, joskus aikoja sitten jokin selain näytti ruudullisen tyhjää tuohon alkuun mutta nuo EPC-kentät ainakin tulivat näkyviin vasta kun selasi sivua vähän. Nyt kyllä tulee siististi näkyviin Firefoxilla ja IE:llä, siis PC:llä. :wink:
Марка :Mercedes Benz Vin :WDB1231201A151262 Модель :123.120 200 D DataCard
Группа
M Motor
GM Manual Transmission
24 ENGINE SUSPENSION
25 CLUTCH
26 TRANSMISSION
29 PEDAL ASSEMBLY
30 CONTROL
31 HITCHING MECHANISM
32 SPRINGS,SUSPENSION AND HYDRAULICS
33 FRONT AXLE
35 REAR AXLE
40 WHEELS
41 PROPELLER SAHFT
42 BRAKE SYSTEM
46 STEERING
47 FUEL SYSTEM
49 EXHAUST SYSTEM
50 RADIATOR
52 UNDERSHIELDS
54 ELECTRICAL EQUIPMENT AND INSTRUMENTS
58 TOOLS AND ACCESSORIES
60 BODY SHELL
61 SUBSTRUCTURE
62 FRONT PANEL
63 SIDE PANELS
64 REAR END
65 ROOF
67 WINDOWS
68 COVERING
69 COVERING AND LINING
72 FRONT DOORS
73 REAR DOORS
75 REAR LID
78 SLIDING ROOF
80 VACUUM SYSTEM
81 APPOINTMENTS
82 ELECTRICAL SYSTEM
83 HEATING AND VENTILATION
84 TRUNKS AND CASES
86 WIPER/WASER
88 ATTACHMENT PARTS
89 VEHICLE ACCESSORIES
91 FRONT SEATS
92 REAR SEAT BENCH
93 FOLDING SEATS
97 SEAT ACCESSORIES
98 GENERAL PARTS
99 SPECIAL INSTALLATIONS
tony
Re: VIN-dekooderi
Viesti Kirjoittaja tony »
En saa itsekkään tietoa, mulla varmaan kammo virus,palo jne jne... ym (veli it-nörtti) vääntäny sellaset estot, hyvä et edes foorumille pääsee, jos joku jaksais kattoo munkin auton mitä se "syönny", kiitos. WDB2112261A387405
S204 CDI AMG
W209 240 CLK
Tomp
Re: VIN-dekooderi
Viesti Kirjoittaja Tomp »
sarkki kirjoitti:
tj86430 kirjoitti:
sarkki kirjoitti:
DBFI kirjoitti:
Kokeilin nyt tuota koodia macilla ja safarin yhdistelmällä. Hyvin toimii.
Re: VIN-dekooderi
tony kirjoitti:En saa itsekkään tietoa, mulla varmaan kammo virus,palo jne jne... ym (veli it-nörtti) vääntäny sellaset estot, hyvä et edes foorumille pääsee, jos joku jaksais kattoo munkin auton mitä se "syönny", kiitos. WDB2112261A387405
Jos se venäläisten tieto riittää niin tässä:
Название val
fin
vin WDB2112261A387405
whc WDB
chassbm 211226
chass_ident 1A387405
type 211
subbm1 226
subbm2
auxiliary_drive
body
body_code
delivery_date 030825
engine 648961 30 039682
front_axle1
front_axle2 BE606131086224
heater
interior 835A
lights
model_idx 0
odometer
order_num1 0322080295
paint1 197U
paint2
paint3
paint4
paint5
platform
production_num1
production_order_ref N
rear_axle1
rear_axle2
release_date 030822
retarder 1 030825
rims
service_num
steering
trailer
transfer_case
transmission 722626 04 716492
vin_dc
vinwhc
winch
wiper
Code Текст
M32 CAPACITY 3,2 LITER
U15 Unknown
U16 Unknown
053 YEAR OF MODIFICATION 02/2
07N Unknown
231 Unknown
248 REAR SEAT WITH INTEGRATED CHILD SEAT
249 AUTOMATICALLY DIPPING INSIDE REAR VIEW MIRROR
275 MEMORY PACKAGE (DRIVER SEAT, STRG. COL., MIRROR)
293 Unknown
380 Unknown
401 Unknown
405 MULTI-CONTOUR SEAT, FRONT RIGHT
423 5-SPEED AUTOMATIC TRANSMISSION
489 Unknown
500 OUTSIDE REAR VIEW MIRROR LH AND RH FOLDING
527 Unknown
615 Unknown
803 AEJ 06/1/M/X
810 SOUND SYSTEM
819 CD CHANGER
954 EQUIPMENT PACKAGE FOR AVANTGARDE VEHICLES
988 REG. DOC. AND COC CERTIFICATE WITH EC TYPE LABEL
830A Unknown
220L HANOVER BRANCH
250B Unknown
835A Unknown
tony
Re: VIN-dekooderi
Kiitos Tomp. Onko DBF1:n lista samalta sivustolta kun näyttää laajemman listauksen, tossa ei kyllä ole kaikkia varusteita, mutta kiitos tästä.
S204 CDI AMG
W209 240 CLK
sarkki
Re: VIN-dekooderi
Tomp kirjoitti:
sarkki kirjoitti:
tj86430 kirjoitti:
sarkki kirjoitti:
DBFI kirjoitti:
WTF!!! Mikä helevetin jippo tässä on nyt kyseessä kun muut onnistuu mutten minä, prkl!!! :evil: Edit: Emännän PC:llä näköjään toimii :?
s211 320 cdi -03
Tomp
Re: VIN-dekooderi
Jännä juttu jos PC:llä toimii ja macillä ei. Mulla ainakaan muuta tarvallisuus juttuja ole kuin palomuuri päällä. En keksi kyllä mitään jippoa. Päällä on myös "estä ponnahdusikkunat". Mulla toimii, kun klikkaa linkkiä, kopio liitä toiminnolla syöttää koodin ruutuun ja painaa "ok". Ei tule mitään ponnahdusikkunoita. Ainoataa linkkiä painamalla aukeaa uusi sivu. Omena näppäin (välilyönnin molemmin puolin) pohjassa linkkiä klikatessa aukeaa uudelle välilehdelle.
sarkki
Re: VIN-dekooderi
Tomp kirjoitti:Jännä juttu jos PC:llä toimii ja macillä ei. Mulla ainakaan muuta tarvallisuus juttuja ole kuin palomuuri päällä. En keksi kyllä mitään jippoa. Päällä on myös "estä ponnahdusikkunat". Mulla toimii, kun klikkaa linkkiä, kopio liitä toiminnolla syöttää koodin ruutuun ja painaa "ok". Ei tule mitään ponnahdusikkunoita. Ainoataa linkkiä painamalla aukeaa uusi sivu. Omena näppäin (välilyönnin molemmin puolin) pohjassa linkkiä klikatessa aukeaa uudelle välilehdelle.
Jotain asetuksissa on oltava pielessä. Oon kokeillut palomuuria pois-ja päällekytkettynä, sallinut-ja eisallinut ponnahdusikkunat muttei kuitenkaan. Mutta se siitä! Pitää varmaan siirtyä hopeisen omenan puolelle ratkomaan ongelma!
s211 320 cdi -03
tj86430
Re: VIN-dekooderi
Mac + FF toimii ihan hyvin täällä.
s213 220d -17
Villa Pikkujalo
Tomp
Re: VIN-dekooderi
Safarilla itse seikkailen.
TUUTTERO
Re: VIN-dekooderi
Viesti Kirjoittaja TUUTTERO »
En itte kans saa mitenkää toimimaan tuota. jos joku viisaampi voisi katsoa ja kertoa mitä kaikkea pitäs olla tai löytyy. Vin. WDB2011261F665955
VW T5
fzr1000
