Sivu 1/1
OM606 into 124
Lähetetty: Pe 13.02.2009 05:55
Kirjoittaja Zeitgeist
Hi, it's been a while since I last posted. I've been building up my new shop in preparations for the next phases of my Super Turbo project. My shop isn't quite ready, but I recently stumbled upon a low-mileage OM606 from a '99 E300D, and couldn't pass it up. I know several Finns have accomplished this swap in the past, but I don't believe anyone here in the US has done this. I'd love it if someone with some experience could provide some guidance as to the issues I'll face when installing this engine in my car. I already have a front mount intercooler installed, so that's not a problem. I also realize that the throttle and oil cooler lines might be some of the toughest issues. Anything else?
Kiitos!
Lähetetty: La 06.11.2010 05:43
Now it's been a really really long time since I've provided an update. This engine is still on my stand, though I've worked through nearly all the issues related to this swap. I've converted the wastegate from vacuum to pressure and swapped over the 6mm elements from the 606 injection pump. I still have to settle on a decent throttle arrangement, but that's the last issue to address. I was checking out the rear of the crankshaft tonight and noticed that it appears to be about 6mm thicker than a 603 where it mounts to the flywheel. Am I going to have problems with either the starter engaging with the ring gear, or the speed sensor if I use the stock 603 flywheel...or, should I just use the (much much lighter) 606 flywheel? Anyone with experience with this issue? btw, I'm using a rebuilt 722.3 with V12 clutch packs.
Lähetetty: La 20.11.2010 18:02
Kirjoittaja Forced_Induction
Zeitgeist kirjoitti:I'm using a rebuilt 722.3 with V12 clutch packs.
Can you provide details on this; Is the upgrade compatible with earlier .3 transmissions? Whats the torque capacity? What is done for the torque converter to handle the high power?
