What is the minimum acceptable intercooler piping size for a 617?
The biggest diameter I can use in my plans is 51mmOD because of clearance issues. I have access to lots of Saab 900 piping that would fit my needs very well. But, it's cast tubing instead of regular rolled tube. That reduces the ID to around 45mm. Would that be okay or should I look for some traditional 51" aluminized steel tubes?
It will be used with my VNT turbo running about 1bar of pressure.
Intercooler tube size?
- Forced_Induction
- Viesti:
1982 300D
Maxed MW-Pump, Holset HE221W, straight pipe exhaust, A/W intercooler, W/M injection
W115 300D intake manifold, 2-Micron Baldwin BF7591-D fuel filter, W126 Gen-II front brakes
Webasto TSL-17 auxiliary hear, Battery relocated to the trunk, Factory skidplate, 15mm rear sway-bar
147HP, 220lb-ft at the rear wheels
2006 Honda Rebel Turbo Diesel
Kubota OC95, VZ21 turbocharger, Intercooler, Comet 40C/44D CVT
