compressor and turbo on a diesel OM603!
Mercedes-Benz conversations only
anton
Viesti Kirjoittaja anton »
This summer i builded a om603 super turbo with all the nice stuff. Rebuilded pump by mynä, new mainfold, hx40 turbo, large ic ,aso.
But I wonder if its able to build compressor on this setting.? Ofcourse I´ll keep the turbo and just use the compressor for lowspeed torque. Will there be any problem with the pump? I´m thinking about the ADLA aneroid....
It would be really nice to have the boost set at about 0.5bar directly you touch the pedal.... :twisted:
Samuli H
Viesti Kirjoittaja Samuli H »
Here are some pictures of 5cyl diesel s123 with turbo and compressor. http://www.kolumbus.fi/valtonen.motorsport/
I don´t think there will be any problems with the pump. It increases load when pressure is increased.
One problem could be that low rpm torque will rise so much that it may break the engine or drivetrain.
By the way, how do you like that mynä pump? :D
anton
okey, now I have bought an compressor. An eaton m90. Let the building beginn!!
