617 Turbo MW Governor Full Load Adjustment/Screw Definition
Mercedes-Benz conversations only
Brandon314159
Viesti Kirjoittaja Brandon314159 »
Oh the website I moderate I have outlined the adjustments for and what each screw does in the MW governor found on the rear of the 617 Federal Turbo Injection Pump. It can be found at the following link: http://www.schumanautomotive.com/forums ... php?p=6711
You must join to view the attachment (no way around it) however I think you may find our Superturbo section to be of interest. Please check out the forum and introduce yourself if you decide to join.
I am user "Brandon314159" over on that website.
Thanks!
-Brandon
'81 300SD (485860km) Intercooled
'82 300SD (~480000km)
http://schumanautomotive.com/forums
