Sivu 1/1
om606.962(w 744.6) to w124
Lähetetty: Ma 23.06.2014 22:58
Kirjoittaja kjuuteboom
Hello, i have 1994y W124 E300Diesel, with om606.910 100kw 4 speed aut. tranny, and i have donor car, w210 with om606.962, 130kw w 5 speed aut tranny, atm w210 is in full contition and it would be nice if someone tell me what should i look if i make the change, i know there will be a lot of wires, but is it hard to make it that it would work as well in w124 as in w210 ?
Re: om606.962(w 744.6) to w124
Lähetetty: Ma 19.01.2026 04:44
Kirjoittaja tuxedosever
Yes, it can be done, but it’s a fairly complex swap. The OM606.962 is fully electronic, so the main challenges are wiring, ECU/TCU integration, immobilizer, and adapting the 5-speed automatic. Keeping everything electronic means a lot of work to make it function properly in a W124. Many people simplify the swap by converting the engine to a mechanical injection pump, which makes it much easier and very reliable.
Lähetetty: La 24.01.2026 05:07
Kirjoittaja isaackaa
Yes, it's possible, but the process is complex. The main challenges involve wiring, ECU/TCU integration, immobilizer, and adapting the 5-speed automatic transmission. Many choose to convert the engine to a mechanical injection pump to simplify the swap and improve reliability.
