Lift pump pressure
Lähetetty: Su 15.07.2012 17:20
What is the best lift pump fuel pressure for an M-Pump?
Mine runs 12psi with the relief opening at 35psi using the primer pump.
If I were to use an electric fuel pump, is 35psi too much pressure for the pump to be fed constantly?
