W123 Suspension Upgrades. 15mm Sway Bar
Mercedes-Benz conversations only
winmutt-
Viesti Kirjoittaja winmutt- »
I have recently received lowering springs from vogtland. The drop is 50mm in front and 40mm in the rear IIRC. I will be putting on bilstein HD in the front (already have them in rear) and I have the Moog metal sway bar end links from the 115.
I have found a source for the 15mm rear sway bar and was wondering if anyone had any input on using it or the TD front sway bars. I am running 225/15/60 tires.
