Hi good friends, I found a good OM606 turbo engine for a nice price, so I was planning to put it in my car, the only problem I found is that the 606 pump is controled by an ECU, What can I do to this pump so it can work mechanicaly? Do I need to put in the new engine my old pump from the OM603?
Kind regards
Swaping an OM603 for a OM606
swap pump from OM603 to OM606. some modifications will be required for throttle linkage, but pump itself should work just fine. you'll lose some power, since OM603 pump has smaller pump elements. It's possible to compensate power loss by adjusting on-boost fueling.
1992 W201 & S124 [size=75]TURBODIESEL[/size]
